Thought you guys that tinker might like this - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Northeast Region CT, DE, ME, MA, MD, NH, NJ, NY, PA, RI, VT
post #1 of 2 (permalink) Old 08-05-2012, 09:17 AM Thread Starter
This is a magneto / distributor set up from a 1939 allis chamlers motor grader. (Road Grader) The unit was not outputting spark, i cleaned up the coil, points, condenser, and regapped points - see how it works now
http://www.youtube.com/watch?v=otqGF...hQQ&playnext=1
http://www.youtube.com/watch?v=0eprU...feature=relmfu
The engine on this is neat, starts on gas then you switch itr over to diesel (same engine). When you switch it over the compression release is negated and the disel injection pump is activated, the coil is grounded so no more spark and carb is deactivated so no gas goes in the intake.
When you shut it down you shut it down on gas to clean out the carbon from the diesel.
Amazing.
Kenny
Mercury is offline
post #2 of 2 (permalink) Old 08-05-2012, 12:11 PM
Why not use that to charge up the door knobs in your house?
dariv is offline
