oil type - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 03-14-2007, 04:57 PM Thread Starter
oil type
which is the best engine oil to use i used to use semi-synthetic on my old gsxr due to fully synthetic causing clutch slip is it the same for the vn. and where are all the vn750 riders in the uk begining to think i,m the only one.
mikefish is offline
post #2 of 4 (permalink) Old 03-14-2007, 05:13 PM
fergy's Avatar
Howdy Mike! If I were you I'd do some searching on the oil topic. Read this: https://www.vn750.com/forum/showthrea...ghlight=thread and the links on that thread and you can make your own decision pretty easy. Other than that, we've all got opinions!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #3 of 4 (permalink) Old 03-14-2007, 05:51 PM
tankist's Avatar
Send a message via Skype™ to tankist
as long as it is oil of correct weight and not of "energy conserving" type you are fine regardless of the brand - just use whatever favorite brand you have available localy. i used synth oil last change and nothing is slipping so far.
and as far as sinth vs dino. my take on it is as long as it is correct weight and inside the engine (vs in the bottle) it doesn't really matter since at the end you will have good running engine anyways and any problems with it will not be due to oil but something mechanical. obviously the changes at correct intervals are needed.
Ride Safe
Anton.
tankist is offline
post #4 of 4 (permalink) Old 03-14-2007, 06:03 PM
Drive less, ride more...
theauhawk's Avatar
Ohhhhh...good Lord!!! Not another oil discussion thread.........
Whatever oil type/brand you finally choose, be sure to change it often enough....dirty oil and excess heat are the big stator killers.
Frequent oil changes are obviously are pretty easy compared to any stator swapout.
Fergy's above link does give some good reading, though.
theauhawk is offline
