carb reinstall help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 05-01-2012, 11:55 PM Thread Starter
Super Member
carb reinstall help
I need some help putting my carb back on. I took it off a few months ago for some cleaning a few months ago and when I was putting it back in today I couldn't remember where all of the lines go.
Btw I also ended up doing an ear shave.
I've been looking for pictures to help me get an idea of where everything goes, but with no luck.
Does anyone have a picture of the setup so I can use it as a guide?
I don't even know which hoses are vacuum and which are gas.
Thanks
Olezhka is offline
post #2 of 7 (permalink) Old 05-02-2012, 12:20 AM
If only it had 6th gear..
DavesVulster's Avatar
there's only 2 hoses for vacuum. they're the small ones. left one goes to the fuel valve or petcock, and the right goes to the air valve under the seat, if you still have that emissions stuff, or it can be plugged. there are 4 larger nipples - 2 for fuel lines from the petcock, and 2 for vents (usually the 2 vent one's join into one by a plastic connector close to the carb assembly ) and are fairly close together. the fuel line ones are most likely plastic and farther apart. careful, they've been known to crack and break. run your vent line up under your tank to the plastic cover on the fuel sender. there should be a dummy nipple on the cover and using that it will keep the line up out of the way and you shouldn't have any problerms
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #3 of 7 (permalink) Old 05-02-2012, 01:08 AM Thread Starter
Super Member
Thank you sir
Olezhka is offline
post #4 of 7 (permalink) Old 05-02-2012, 11:22 AM
Quicksilver3602's Avatar
Got some pictures in a Carb album. Check them out....Make sure choke linkage is attached and working properly. Also hook up both throttle cables before re-installing. Then reattach the the choke cable after you get them in position. Way easier to install throttle cables while the carbs are off bike. It is possible to get them hooked up while on the bike.....but you will use every bad word in the book.
2003 VN750
Deka MF Battery
Cleaned and Rebuilt Carbs Multiple Times
NGK Iridium Plugs
New Plug Wires
New Petcock w/screens
Fuel Tank Rust Removal - The Works Method
ACCT to MCCT Conversion
Brake Fluid Flush - Nice and Firm now
The List
Spline Lube
Fork Seals/Dust Caps
New Front Tire
HID Headlight Kit
Quicksilver3602 is offline
post #5 of 7 (permalink) Old 05-02-2012, 09:31 PM Thread Starter
Super Member
Hooked everything up and it looks like it's all working fine.
Thanks guys
Olezhka is offline
post #6 of 7 (permalink) Old 05-02-2012, 09:53 PM
Thanks guys
Nice to see another So Cal rider.
post #7 of 7 (permalink) Old 05-02-2012, 11:01 PM
Thanks guys
Glad to hear it. Best of luck.
Dave
Mods:
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Tunes
