I think a lean mix usually causes blueing on the pipes, but maybe it could be yellow too.??
Are you experiencing excessive popping or backfiring when decelerating?
That can indicate a lean condition. Check the "Verses" for marbling or coastering in the exhaust section.
Here is a spark plug color picture to help "read" your plugs.
http://www.google.ca/imgres?imgurl=...=183&hovw=275&tx=155&ty=105&page=5&ndsp=14&ved=1t:429,r:1,s:53&biw=1090&bih=419
You want a light tan or gray color on the ceramic insulation.
Too light or white indicates a lean condition.
Black or soot indicates rich/flooding or burning oil.
The air/fuel mixture is factory speced at 1 5/8 turns out for US bikes.
Try 2 1/2 turns and test ride. Increase 1/4 turn at a time if needed. 3 1/2 turns max. Screw falls out at 5 turns. Seal with dab of silicone when adjustment is done.
