Hello all
I have a 98 vulcan 750 - I have a question regarding my carb - If anyone could shed some info on this I would appreciate it
The layout as follows - wanted carbs cleaned - no one wanted to touch the job - so I did it myself - all went fine for the removal, and the cleaning process within reason with a hic up or two but nothing monumental - not bad for first time i suppose.
the reinstall - different order - I have a second bike for parts - and I'm quite careful to study that bike before touching mine - I use it as a template just to ensure I'm in the correct form on anything I attempt.
As we took the carb out of the running bike I saw the throttle linkage area was sheared off - not a big deal as I had another carb on the parts bike - which i knew runs fine when purchased.
Now somewhere in the transfer of carb hoses I mucked up poorly - because once all went back together we started the bike and it ran for a few moments then fuel leaked every where including out the exhaust. Bike was off got it towed in lieu of trying again cause the lady upstairs from garage was non to pleased of the smell.
The mechanic is good a bike builder - but a harley bike builder - good man good hands but different bike all together.
I got the bike back he say it runs better than before bla bla bla......I rode the bike an instantly feel the difference in power. complete restriction on throttle accel. When i got the bike back to garage i study it further an notice he has added a T connect to my primary line from the petcock and from what I believe is the vacum line on the rear cylinder side of carb he linked the new T hose from vacum into the underside of gas tank.
I removed the hose from the gas tank area and feel a little less hesitation - but still no where what I once had. As I recall prior to disassembly that was a vacum line because it was capped off - and when I removed the cap the ran choppy - cap on bike smooth and full power...Now I have that vacum closed off and T into my primary. Bike runs as I said starts runs and rides - but not the same.
One note that I left out was when we started the bike on the initial reinstall of carb - fuel shot out that vacum section also - now its tight no leaks no error.
My question or theory is if i remove that added T section and cap off the vacum area would that be correct?...Or....did this mechanic find another way to hook up the carb - just with a bit of power loss - also what would be the turnout to machine over time - should I decide to leave it this way? I know my bike well I know it's not running to her full potential - until I have the chance to find a spot to do my tests I will not know. Perhaps you guys know better
Thanks I appreciate it
