Economical light bar - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 09-12-2007, 12:31 AM Thread Starter
Custom fabracated (sounds better than home made) light bar out of 1/8" stainless. Cut to fit, then installed Mini Cooper running lights. These lights are 5 1/4 dia. I think the 4 1/2 lights might look better, but they work great...
Pictures at this link:
http://www.kodakgallery.com/wayland
wayland1 is offline
post #2 of 14 (permalink) Old 09-12-2007, 01:05 AM
oglejust's Avatar
pix dont work
.... slightly modified
oglejust is offline
post #3 of 14 (permalink) Old 09-12-2007, 05:33 AM
I can't get to them either?
Could you maybe have the pics set to private?
post #4 of 14 (permalink) Old 09-12-2007, 02:21 PM Thread Starter
I thought I was set, but Kodak wanted $25.00 to be public.. So try this link. Thanks http://www.kodakgallery.com/wayland
wayland1 is offline
post #5 of 14 (permalink) Old 09-12-2007, 02:26 PM
BMan23777's Avatar
Nice work!!!!
Brian Manchester
'89 "GRIMM"
04 durango AWD
BMan23777 is offline
post #6 of 14 (permalink) Old 09-12-2007, 05:04 PM
I like it! I have 2 questions for you I'm sure you've been asked the first. Did you rejet? or do those restrict enough air. 2nd the lights look great but are they going to draw too much power? I'm presuming you checked into that.
post #7 of 14 (permalink) Old 09-13-2007, 12:05 AM Thread Starter
Am experimenting with jets now mainly for the exhaust change. All the intake plumbing under the tank is still being used. The lights are supposed to pull 55w each. Haven't checked it other than that.
wayland1 is offline
post #8 of 14 (permalink) Old 09-13-2007, 12:36 AM
I think 55w each is a little much for non-highway use. I do like the lightbar. Simple and low profile. Nice job!!
2001 VN750
Vista Cruise Control
V-Force shield
Kawasaki Saddlebag supports
Fixed trunk hinge
TOC MCCT
Clear Alternatives LED tail light
Knifemaker style floorboards
Knifemaker style dash
Avon Venom X 110/90 Front
Avon Venom X 170/80 Rear
Big Crank AGM battery
25,100 miles as of 04/20/2010
lancer19 is offline
post #9 of 14 (permalink) Old 09-13-2007, 02:00 PM
darrelc5's Avatar
The light bar is awesome!
Please aim these down and do not blind me when coming the opposite direction. Remember, you're representing us all.
Darrel
'03 Vulcan 750 (90k miles)
-Corbin Seat
-V-Force Windshield
-LeatherLyke Touring Bags
-Chrome Luggage Rack
-Headlight Modulator
-Brakelight Flasher
-MF Battery
-Heads-Up Voltage Monitor
-Replaced Stator (9,000 and 16,000 mi.)
-Oil-cooled Stator Mod (photos)
-Replaced and Relocated R/R
-Greased rear splines
-Fused Stator (photos)
-Metzeler ME880 Marathon 170/80-15 (Rear), 110/90-19 (Front)
-TOC MCCTs installed
-Headlight Relays
SOLD - 2013
darrelc5 is offline
post #10 of 14 (permalink) Old 09-13-2007, 02:55 PM
Scoop's Avatar
Very nice fab job on the light bar. How did you cut the stainless?
97 VN 750
R&R Relocated
Degoated
Ears Shaved/Rejetted
MF/AGM Battery
Irridium Plugs
Spring Solo Seat
32 Ford Model A Tail Light
Rear bobbed and hard-tailed!
Scoop is offline
