Hi all, I'm new here, and I hope you won't mind if I post questions about my 1985 VN700, since its effectively the same bike...
I had a stupid new rider problem a couple of weeks ago, in which I thought "Pri" on the petcock was for Primary. So gas flooded the carbs and got into the crankcase. My basic symptoms was that it would not start when warmed up. I changed the oil (and filter) and cleaned the screen. I idled it a couple of minutes to fill the oil filter and topped it off.
I took the wee beastie out today after this, after letting it sit for a couple of hours. She ran a little bit better after this, however I've still got a couple of hanging on problems. When I started it several times today, the bike started right up, but as soon as I turned the throttle, it would die. Either that or application of throttle would make it rev, but not come back down to idle. There is no rhyme or reason to this. In fact, a couple of times, I actually had it die when riding (hitting the start switch was enough to bring it back to life).
The other thing I noticed was a clattering sound from the bottom of the engine, at low RPMs. (Clattering might not be the right term, but its the best I can come up with.) I'm not sure if this is normal, but in the event that it is not, I wanted to bring it up before I damage anything.
All of my riding today was in my subdivision, mainly riding cul-de-sacs, speeds 30 MPH or less, 2nd or 3rd gear.
Any ideas?
Thanks,
--Storm16
Any ideas?
Thanks,
--Storm16
