1 - 11 of 11 Posts
Actually, it's a "lowered my Vulcan" thread. I did the 1/8 plate with a shackle relocation bracket, and raised the forks just a hair under an inch. I got finished about the time the wife and kids got home so I haven't test driven it yet. It feels pretty good sitting on it, the back seems pretty stiff. I'll end up pulling the bracket off and just changing shocks, but I wanted it lower today and didn't want to wait. I'll post pics tomorrow or over the weekend.
Melissa Fahye has 10.5" progressive shocks and moved the forks 1.5" and handles well,just the footpegs scrape more;)
How do you move the forks?
Loosen up the triple tree and slide the fork.but I don't recommend doing it unless the rear is lowered, as the handling will get very wonky
If you are doing it for cosmetic reasons, I wouldn't. I routinely drag the pegs in turns on my stock Vulcan (I'm nearly 260 pounds) Less ground clearance would probably make it easy to crash in sharp turns, like at a stoplight.
Dats were yas gots to be careful.I only drag pegs when I'm REALLY into it.it's not a crotch rocket and anyone who buys a Vulcan already knows that.and if you crash from scraping pegs at a stop sign you might not realize what thaw word STOP means.;)
Discussion Starter #7
I did it because I'm a short guy. I took it a bit over 100 miles yesterday, no bottoming out on the railroad tracks or bumps, but I did drag the center stand a time or two.
I started off with big triangles and worked them to shape. I didn't cut the rear of the brackets down because my wife proclaimed the pointy bit "bad ass."
Sweet.I removed my center stand
Senior Lurker
Does the bike sit ok when parked and on the side stand?
-Sloppy
Had to heat my side stand up with a map torch and bend it
1 - 11 of 11 Posts
