1 - 5 of 5 Posts
I've searched through some of the earlier threads on diagnosing and fixing the source of vibration, but I'm not sure where my particular case falls.
I have both a '94 and a 2004 VN750, the latter to replace the former once I get some paint work done on it. One thing I've noticed though is that the '04 bike, while generally as smooth or smoother than the '94, vibrates a lot more than the '94 one, but only at engine RPMs over 3,000. Under that and it's fine, but once it hits 3K on the tach, something vibrates, seemingly primarily in the front right side of the bike but I haven't tracked it down yet.
Any suggestions? I can duplicate it on the centerstand so it's not something that requires resistance on the wheels. I'm hoping it's a frame or handlebar bolt somewhere, though they all seem pretty tight to me.
On His Lady Vulcan
I was going to suggest that you look at and make sure the motor mount grommets (rubber) are in good shape, but I am sure that you have already inspected them??? Good luck
Peace :beerchug:
All bikes run differently. The more miles ? on the older one may be the reason it seems less smooth. The rubber in the mounts may simple have compressed more over time and allow it to vibrate a bit more.
My suggestion is to stop worrying about little freaking issues and go out and ride.
My suggestion is that if it bothers you (and if it didn't you wouldn't have requested input), try to track down the cause and eliminate it, if possible.
Discussion Starter #5 (Edited)
The odd thing is that it's the NEWER bike (with 26,000 fewer miles on it) that is rougher. Today I went over the bike and tightened all the bolts I could find on the headlight, forks, engine mount, etc., and it does seem better...
It could also be that I feel the vibration more through the still-stock grips than the Kuryakyn ones I put on my older bike (still waiting for the Kurys for the new bike to arrive). After doing the bolt-tightening I parked the two side-by-side and revved their engines up to 4-5K, they seem to cause pretty much the same level of vibration on the frame.
What's really keeping me from riding it now is that I'm also still waiting for the windshield for the new bike to arrive. Riding at 50 MPH without one really forces me to hold on to the grips, and the stock grips are so thin (I have pretty big hands/long fingers) compared to the Kurys I'm used to!
1 - 5 of 5 Posts
