1 - 6 of 6 Posts
Going through the process of re-assembly after a stator and rotor swap. On the front left downtube there are several wires. I have plugged the fan up, and connected the sensor on the bottom of the radiator. However I am now left with two bullet connectors there that I don't remember disconnecting and can't figure out what they go to. One is blue and one is brown. According to the wiring diagram, the only blue/brown pairs are for the front and rear brake light switches. Does anyone know what these wires are for?
Sounds like the pair for the rear brake light switch (foot pedal), though I haven't checked the colors.
Went out and checked but can't easily get to them without pulling the radiator.
They probably got pushed over to the wrong side when you put it together. I agree with Spockster, I believe they go to the switch on the rear brake pedal.
OK thanks I'll take a look when I get home tonight. I haven't installed the foot brake yet so that's probably the case, just threw me off when I saw them on the left side.
Chucklehead
Two wires together with bullets ..... rear brake switch. Just looked.
1 - 6 of 6 Posts
