1 - 4 of 4 Posts
Discussion Starter · #1 ·
Hi. Which ISO grips should I get for an 06 VN750? I know I need 7/8". I was about to order the universal grips (#6241) and then I read a post saying to get #6180 (for the goldwing).
Someone help!
Thanks, Mark
Get the goldwing ones. The other ones are too short and you will end up with a gap on the throttle tube side. The goldwing ones also look/work better with the universal vista cruse (throttle lock). The goldwing ones also give you more room to move your hand around.
I have the goldwing ones as do several others. At the gathering I did see a set of universal ones and noticed the small gap. Also, there is more solid chrome (before the rubber iso part) near the controls which also helps with the vista cruse
Discussion Starter · #3 ·
I installed the ISO grips this weekend and absolutely love them. They're thicker than the stock grips but very comfortable. I recommend them highly.
I also put on a vistacruise throttle lock and had mixed feelings. It works as advertised but I guess I was expecting more of a cruise control effect. I found I sped up going downhill and slowed down uphill - which I should have expected since there is no speed compensation.
The guy that comes up with this thing will make a mint.
1 - 4 of 4 Posts
