1 - 15 of 15 Posts
A couple of years ago there were some on Ebay which some members installed, but they don't seem to be listed anymore.
Just did a search on Google for "braided stainles steel brake lines" and found several hits.
https://www.google.ca/search?source...cp.r_qf.&fp=a1243ebe7999b6eb&biw=1366&bih=584
I recall one member whose new kit ran two full length hoses from the master cylinder down to the brake calipers.
Something like this link: http://www.motorcycle-superstore.co...ersal-Braided-Stainless-Steel-Brake-Line.aspx
Make sure you get enough new copper washers/seals and a longer bolt to pass through two banjo fittings and into the master cylinder. :)
EBAY STAINLESS STEEL BRAKE LINES on eBay
The only two places I know that make QUALITY SS brake lines are the aforementioned Galfer and Russell:
http://www.russellperformance.com/mc/brake_hoses/universal.shtml
I have no experience with others on the market, but just again warn buying cheap eBay lines if you're not sure who makes them.
I also suggest losing the stock "splitter block" and running duel hoses right off the MC if you can. (this requires a duel banjo bolt...
http://m.motorcycle-superstore.com/...visionId=4&DepartmentId=437&ItemStyleId=32835 ).. Or, just using a simple T fitting.
100% Black & White
100% Black & White
I can only find that in the UK... i have cross referenced the brand as well as the part number. every hit comes for the UK.
ah, ok... Thanks for looking Slim. I guess it's a UK only brand. Pity, as they really are excellent.
i can find the brand in automotive applications, dirt bikes and sports bikes, just not cruisers, and the part number listed on ebay references back to a Goodridge number that only sells in the UK
100% Black & White
Just had a look at the part number on that eBay auction and it's different to the one listed by my local Kawasaki agent. They are showing the number as KW0753-3FC. Don't know if that would make a difference?
Edit: Just found a vendor in CA who has them under a totally different part number but I'm not sure if this is a 2 hose or a 3 hose kit. You'd need to check with the vendor to ascertain exactly what is in the box....
http://www.1tail.com/Goodridge/Brak...ided_Brake_Lines_-_Front_-_11-K2825-F/712031/
I used to get my beard braided years ago with letter beads in it when it was longer...lol...
I know, that doesnt help....just wanted to be a lil funny....sorry....:( ;)
http://m.motorcycle-superstore.com/I...mStyleId=32835 ).. Or, just using a simple T fitting.
Just curious..... why/what advantage in your opinion ?
tia
WilliamTech
It makes bleeding the brakes alot easier. The stock splitter thing seems to let air bubbles hide inside of it.
k, thanks km
WilliamTech
1 - 15 of 15 Posts
