1 - 10 of 10 Posts
Hi I just installed a new engine and I'm reconnecting everything and ran in to a a slight problem i have 3 wires all yellow i think they run from the transmission maybe the stator the problem is i don't know how to reconnect them they're not marked i dont wanna short them or blow a fuse if anyone has a clue please help thank u in advance!
Dr. Vulcanstein
Can you show any pics for clarification?
Three yellow wires "together" should be coming from the Stator....they are to be connected to the Regulator/Rectifier...
:smiley_th
The 3 yellow wires go to the stator, doesn't matter how they get connected.
True...on the Stator end.
The other end it does matter how/where they are connected.
:smiley_th
:smiley_th
Are you referring to the side that is on the wire harness?
If so those 3 wires can be mixed and matched. They are all power wires from the stator to the regulator. All three wires should be bullet connectors.
Yes, this is true (on a Stock/Original Factory unaltered Stator)
:smiley_th
:smiley_th
I'm hoping he upgraded, I'm so happy having the mosfet reg and TPE stator. I never worry about the charging system now. But if not then it should be an easy plug and play.
This makes me very happy. I just replaced my entire wiring harness, and that was the only remaining question I had. Once I get my new fuse box, TPE stator, and my MOSFET in I should be good to go. Psyched
1 - 10 of 10 Posts
