1 - 4 of 4 Posts
Discussion Starter · #1 ·
Can anyone please give me the bulb number for the tail lamp/stop
lamp for the VN750? (1156 or 1157) ?
Also is the turn signal flasher a 2 pin/spade connector with ground?
Would the connections be?
+ to flasher
Flasher to T/S switch
Flasher to ground
Thanks for the help.
+ to flasher
Flasher to ground
Bulb number is 1157, dual-filament for running light & brake light.
1156 is a single filament bulb...running light only.
Can't help you re the flasher...I've never had mine out.....
Discussion Starter · #3 ·
Thanks John. Looks like they are the same ol, same ol bulbs that's been around since dirt was invented. Sometimes, old is good, and I know because I'm there.
Forum Faciliator
I don't know the turnsignal bulb #'s either. Although the front ones are probably duel element ones and the rear single, since the front are on when the headlight is on and also work as turn signals and are three wire turn signals where the rear only have two wires.
However I would guess that if you took them out and took them to a local auto parts store you would not have any problem getting replacements for them.
If you find out the numbers, please post.
Thanks
RB
1 - 4 of 4 Posts
