1 - 5 of 5 Posts
Chasin' the blacktop
Ok, this may have been discussed before but I can't find a solid answer so..... What is the best battery for our bikes out there? I put an AGM battery in 18 months ago but it seems to be getting weak already and I want to use the longest lasting highest amp engine spinning battery out there.
Tell me, short and sweet.... what is the best battery for our bikes?
EDIT: iirc, From the spec's I observed, all AGM Battery to fit our bike are the same CCA Rating.
There has been no preference by brand - other than price & availability.
How's the Charging System ?
14. + V @ 3 K rpm ?
:smiley_th
Deka seems to be popular, but everyone has a different opinion based on price and availability.
If your AGM battery is worn out this quickly, then I would check your charging system as WilliamTech is eluding to.
READ the Verses section...all you need to know is posted there for people to find it easily.
Guess should ask what AGM battery you have now. My Westco battery lasted 7 years...I'd say more than that but I sold it. The stock AGM in my FJR lasted exactly 7 years.
So, you either got a bad battery or something's wrong with your charging system. Right now I'd just say avoid any cheap Chinese battery, as the rest all seem to be doing well. (I bought a Motobat battery for the Yamaha BTW)
http://www.motobattbatteries.com/?gclid=CK6c3dGggLsCFeZFMgod3GkAiQ
I'll check the charging system. With the cooler weather the engine seems to be struggling to spin fast if I haven't started it in a few days even though it's at least 50 degrees. I'll check the battery type and report it later.
1 - 5 of 5 Posts
