1 - 10 of 10 Posts
Since I put in the new stator and R/R, I've noticed an increase in electrical problems. In trouble shooting these problems it has driven home just how delicate our electrical systems are.
One problem that I encountered was turning on the key, hitting the starter and all the lights go out. Let her sit for a minute and they come back but hit the starter and out they go again. I was beginning the think we had some kind of thermal protection device that cut power when over heated. As it turned out, the wiring from the battery to the starter solenoid is very finicky. You must have absolutely clean and tight contacts here. Both on the battery side and starter motor side. I tumbled onto this because I took the side cover off and noticed a puff of smoke from one of the terminals when I hit the starter button. I cleaned the offending side of the solenoid and everything was great for about 3 weeks. Last week, I was ready to go home from work and I turned the key and NOTHING!! No lights, nothing. I thought maybe something had shorted since I lock the steering at work. I took the right side cover off again and wiggled the solenoid and got lights but no start. Ended up jumping her to get to an appointment and then home and it seemed OK. Next day though, lights but no start. Today I started troubleshooting again and discovered that the positive lead had loosened up from the battery causing the problem. Just to be safe I also cleaned the other solenoid contact and did a continuity check of the wiring.
With any electrical problem, ensure all of your contacts, junctions, and terminals are clean and tight. One loose connection can drive you crazy.
I had also noticed that my headlight and instrument lights pulsed when the bike was at idle. I thought maybe a leg on the stator had gone again but it turned out the be a loose connection to the R/R. I have individual blade connectors going to my R/R since battery acid and contact overheating destroyed the factory MOLEX connector. Again. clean and tight contacts are the key. I don't think I can emphasize this enough.
Hope this helps someone who is having issues or prevents someone from having the same problems I've had.
...........With any electrical problem, ensure all of your contacts, junctions, and terminals are clean and tight. One loose connection can drive you crazy. ....
There, that whole big paragraph boils down to that one simple looking line.
It has always amazed me how many times a entire host of problems ends up being something as realitively simple as a loose contact somewhere on the bike.
Way back when I worked in a bike shop , I lost count of how many times a customer would bring in a bike with some electrical issue...claiming a bad alternator, bad coil, or such...only to find the cause of their problem was not a failed component, but a bad connection.
Through the years here and on the Yahoo group forum, I have also lost count of the times the final solution of someones electrical problem turned out the same way also.
It has always been my opinion that the majority of times a component has in fact failed, like a R/R or stator, it was caused by poor or loose electrical connections somewhere on the bike, and the best thing you can do to ward off any potential problems with these units is to make sure every connection on your bike is clean, strong, and tight.
So , before something "goes wrong" take an afternoon with a can of contact cleaner, a sheet of emery cloth and a tube of dielectric grease, and go over evey connetion like the bikes life depended on it. It kinda does.
Drive less, ride more...
I'm gonna have to give a strong second on SR's and KM's recommendations here....:rockon:
A few weeks ago, I pulled the 6-pin connector off of the R/R, to make sure the dielectric grease there was holding up ok.
In the process, I worked the connector back on and off several times, and also regreased it.
I also pulled the connectors out of the rear of the junction box, inspected them for cleanliness, and reattached them.
Since then, I've noticed stronger voltmeter readings--especially at lower rpm's.
If this sort of preventive maintenance will work for a "younger" bike like mine (a 2005 model), think what it could do for an even older VN750....:doh:
So KM and SR are indeed right...apparently we need to modify the bike's "official" maintenance schedule to read something like, "once a year, inspect/clean/grease (dielectric)/tighten all electrical connections and battery terminals/frame grounding."
For many folks here, it might be a good idea to work the above during the non-riding (winter) season, when the bike is otherwise in storage and precious riding time isn't otherwise wasted turning screws/wrenches and dabbing grease.
In any case, be sure to use a cleaner for the above that is formulated for cleaning electronics--it MUST specify on the cleaner's container that it is safe for plastics!!!
Heck, this bit of TLC might even cut into the stator and R/R failure rate.....:smiley_th
Calif Rider
I agree with everything that was said by everyone. Anyone who was or is a machanic will, or should tell you that preventive maintanance is the best maintanance. Catch the problem before it is a problem, saves a lot of money in the long run.
IBEW 915 Electrician
If you are chasing electrical problems and you disconnect the battery while the bike is running and the engine dies immediately are we still in the realm of a bad connection or has the problerm shifted onto the stator/RR?
I think if you remove the battery while the bike is running..even if the battery is almost dead..the bike will stop because you in effect "cut the circuit" that makes you bike run. ..it will not run without a battery...and will not run without one with some charge left.
Do Not Disconnect Battery With Engine Running
From CLYMER MANUAL, PAGE 300, Transistorized Ignition System Precautions
paragraph 2. Do not disconnect the battery when the engine is running. A voltage surge will occur which :( will damage the voltage regulator/rectifier :(and possibly burn out light bulbs.
para. 3. Never disconnect any of the electrical connections while the engine is running.
Take note anyone who has contemplated doing this. It will cost you $$.:(
Love My Baby
All the above wisdom pertains to more than just our bikes. I troubleshoot malfunctioning electronics, appliances, and medical equipment all the time, and I have found that a sizable majority of problems occur because certain electrical contacts are tarnished, not tight or worn and don't make good contact. Simply cleaning, tightening or doing whatever to improve the point of contact is often all that's needed.
Discussion Starter #10
Tear it apart and put it back together technology!!!
1 - 10 of 10 Posts
