1 - 5 of 5 Posts
Not sure exactly what it is, (note I stole the photos from someone elses forum). I pulled the mechanical seal and came across a red soft, ring, almost silicone like, pulled it out and then a metal washer, behind all that finally the bearings. What is the red thing, and can I replace it without splitting the case? (Praying I don't have to split this thing)
52967
That looks and sounds like you removed the outer portion of the sealed bearing for the water pump shaft. You will need to look at replacing the bearing (from the inside of the case). Sorry.
  • Like
Reactions: Spockster
I concur, unfortunately.
1 - 5 of 5 Posts
