1 - 3 of 3 Posts
It seems my front brake pads drag slightly on one of the rotors at a certain point on the rotor. I think it's the left one but not completely sure. With the bike on the center stand - when I spin the front wheel I can hear it drag at a certain section of the rotor.
I'm assuming this means my rotor is warped or uneven (?). Could it be anything different? Could it be a problem with the wheel?
I'm looking for any thoughts or advice. I haven't worked on brakes on a motorcycle before.
Thanks in advance
Chasin' the blacktop
If it's just one rotor then it may be warped but worn wheel berings could be causing your problem.
Bearcat
Check the wear on your pads and see if their evenly worn. A warped mc rotor is like on a car. Easiest way to test is to get up to speed and then brake normally. Pay close attention to the way the front feels. If its warped you will have a shimmy eather in the whole front end or possibly a pulse in the break leaver as the pads are pushed back in on the high spot on the rotar pushing your lever back out.
I put new pads on both sides of my bike last fall and you could hear the pads rub at a cretin spot on mine. After a few hundred miles the new pads had seated to the rotars and now theirs no drag. If all else fails and you don't fell safe you could always have a mc shop check it out.
1 - 3 of 3 Posts
