I just purchased a 1995 Kawasaki Vulcan 750 from a dealer for an amazing price. I took it home and noticed that it actually had an oil leak - now I know why I got it for $800. This is my first bike ever, so I am really disappointed as the dealership said that everything was perfect. I have absolutely no mechanical experience, but I have been doing nothing but researching what could be wrong the last few days (this forum has been especially helpful). However, I never found a leak quite like the one I have.
I have attached a few pictures to help you guys understand. I'm sorry if I don't use the correct terms too, I'm trying! haha. On my left crankshaft where the oil reservoir is (reference "Motorcycle1" picture), I have this ring of black apoxy all the way around the part (pointed to with a red arrow in picture "Motorcycle2"). This apoxy, from what I understand, was put there by the manufacturer - not by a previous owner. My leak though is on the bottom of this oil reservoir at - from what I can tell - two bolts near the drain bolt (circled in the "Motorcycle3" picture). There was a yellow/white type of silicone on top of this black apoxy, but it didn't really seem bonded to the area, so I just pulled it all off. I'm assuming that a previous owner knew about this leak and just tried to seal it up with the silicone. It obviously didn't work!
Anyways, it only leaks when the motorcycle is running. It does not leak when it is cold. When it is running oil will drip from one of the two bolts at about 1 drip per 5 seconds (about 70mL an hour). I've rode it for about 30 miles total so far, and it seems to run perfectly fine. I've done an oil change and it does have the correct amount of oil in it (I had a more experienced friend help me). My question is, what do you guys think is wrong? I'm wondering if my gasket is bad, or possible the O-rings on the bolts (are there O-rings)? I would like to get the leak to stop but don't want to take out the engine to replace the gasket / o-rings, so I'm probably going to try to put that really nice JB weld all along this seam, right over the black apoxy. What do you guys think? I wanted to try this first, and then maybe get into more technical things!
Sorry for the wall of text, I just wanted to make things as clear as possible! :rockon:
