1 - 4 of 4 Posts
Hey all, a while back I attached my rear turn signal wiring to the integrated lights on my Mutazu hard cases. Well, I guess those integrated lights must be LED because my turn signals were flashing kinda fast. I decided to install a universal flasher which I thought would be plug and play to our turn signal relay. It didn't work at first, so I hit up the wiring diagram. Turns out, it was almost plug n play, but our turn signal relay has the power and ground reversed from a DOT universal flasher. So, I used a jewelers screwdriver to push in the catch on the pins, pulled the pins out of the stock plug, and switched their positions. It works great now, and even came with a little rubber holster to install it in the stock position. I thought I would share some pics in case it might help someone else.
Sent from my SM-J700P using Tapatalk
1 - 4 of 4 Posts
