Instructions can be found elsewhere on the site, I just wanted to get the parts list in one place since I've asked it myself and seen it asked many times since.
NOTES:
If you're doing the stator, do the dampers. If you're doing the dampers, inspect the stator.
And a little tidbit Spockster mentioned after installing his balancer 180 degrees off:
"Always remember, the largest hole in the damper gear, remains empty."
Tools Needed:
-metric sockets/hex keys/screwdrivers, etc.
-floor jack to remove engine
-friend to help (the engine is HEAVY!)
-Ft-lb torque wrench capable of torquing counterclockwise
-rotor puller bolt (M18x1.5 threads)
-Thread locker for balancer gear bolt
Parts Needed:
-stator (check for latest recommendations on brand/source)
-Rubber Dampers:
-- 92075-1747 (x4)
-- 92075-1748 (x2)
-Stator Cover Rubber gaskets:
-- 92055-109 (x3)
-- 92055-1319 (x1)
-Stator Case Paper Gasket:
-- 11060-1089 (x1)
-Exhaust Crush Gaskets:
-- 11060-1119 (x2)
Other recommendations:
-Upgrade the R/R to a MosFet or Series style if you haven't already; all it takes is a little crimping/soldering and to fabricate a simple mounting bracket. (FH020AA or SH775 style, can be found used by searching for a FZ-09 regulator or a Polaris 800 regulator on eBay. Brand new kits available at Roadstercycle. SH775's are supposedly better for stator longevity, but MosFets are still way better than stock R/R's. Get the Furikawa QLW-250 connectors for a waterproof R/R install)
NOTES:
Tools Needed:
Parts Needed:
-Rubber Dampers:
-- 92075-1747 (x4)
-- 92075-1748 (x2)
-- 92055-109 (x3)
-- 92055-1319 (x1)
-- 11060-1089 (x1)
-- 11060-1119 (x2)
