So I put new bulbs in the turn signals and only the front right works and when I try to switch it to the left the relay just makes sort of a buzzing sound is my relay bad
StandardStandard or LED bulbs?
Yeah they’re all rughtOk, make sure they are the right bulbs, 1157 in the front and 1156 for the rear signals. If the relay is buzzing I’d go straight to that if the bulbs are all correct. It’s real easy to pop it out and replace.
I’ll get a new one and hook it upGood chance the relay is shot then if the bulbs an wiring looks good.
It doesnt work only front righthAs mentioned above, you should try the 4-way,
The relay provides power to the signal switch and the hazard switch through only 1 wire. The relay doesn't care which side is connected.It doesnt work only front righth
Ok then I’ll check the wiringThe relay provides power to the signal switch and the hazard switch through only 1 wire. The relay doesn't care which side is connected.
The terminals are Battery, Ground and Lights. There isn't a left or right terminal on the relay.
If only one side works, then the problem isn't the relay.
Since the left side doesn't work with either the hazards or the left signal, it's likely a problem with the wiring after those switches or a problem with the bulbs.
