1 - 20 of 54 Posts
Alpha Geek
Firstly, if you don't want to read all of this or can't quite grasp it all, that's ok. Just look at the first section. Any more fuel than that, and you need to sort out some other issue (or you have a turbo on that beast, take pics. And video!).
Secondly, I've had a fair amount of experience tuning/jetting carbs on Keihin CV carbs on 3 different types of bikes and have learned several things. At the time I'm rewriting this for VN750, this includes 3 personal VN750s of mine and maybe a couple dozen other bikes. This includes all combinations I've seen of stock/Emgo/K&N/Moxi/unfiltered velocity stack intakes and stock/degoated/h-piped/straight piped/drilled muffs/swapped baffled muffs/unbaffled mufflers which are basically just big cans. Please keep that in mind.
I hope this guide can help a lot of people. Since a certain member passed away some time ago, we lost a fair amount of experience with tuning. I picked up where he left off, dug deeper into the peculiarities of CV carbs, and have run a TON of tests to give people a good place to start. Being on this forum less often, I'm not as available as I was to answer the questions I've had on tuning individual bikes. Hopefully this helps :)
Finally, I adapted this write-up from another model of bike. If I've made a mistake somewhere or missed anything that needs to be changed for VN750s, just let me know.
I've moved this section to the top for ease of use.
Estimated sizes:
Again, I haven't been able to test a CX500 since I just got one as a project, but I recommend starting here:
+3% Intake pods only
+3% more open mufflers, H pipe, or crossover removal
+3% (in the high range) Removing H box and AGGRESSIVE straight piping (for some bizarre reason, the Vn750 lingo is the "goat's belly" instead of a crossover, resonator, or Honda/Kaw's term "power chamber")
If you're doing only pods, or pods and swapping mufflers, you might get away without rejetting at all. Every bike is different, but most people who rejet are dumping WAY too much fuel in.
Jet flow rate chart (approximate):
Code:
Size #	Area	From stock
35	.0962	- 12.5 %
[B]38	0.110	(stock)[/B]
40	0.126	+ 15%
42	0.142	+ 29%
130	1.327	- 3.77 %
[B]132	1.379	(stock)[/B]
135	1.431	+ 3.8%
138	1.485	+ 7.7
140	1.539	+ 11.6
142	1.595	+ 15.7
Point 1: Understanding consequences of intake/exhaust changes
This almost invariable changes the intake flow and dynamics of the carbs, and since they rely on air velocity for atomization and also vacuum for operating the slides it can be noticeable. Often there is a loss of power or driveability especially in the low range, or sometimes in the transition from the pilot circuit to the main (especially on a Keihin CV style carb). You can compensate for one or the other, but it's hard to hit both just right since the air intake isn't the same as they were designed for.
In any case, there will be a difference, whether you gain or lose power at different RPM or throttle position. It's "choppier" because a longer intake has a smoothing effect on the air flow, and a joined intake has even more smoothing effect on the air pulses like exhaust scavenging in a 2-to-1 or 4-into-1 pipe vs independent "drag" pipes. When you ditch the air box, you lose those. Since the new intake is like a short tube header, it's often going to flow more smoothly and efficiently at higher RPM and have less gain or even a negative net effect on the low end. That means a larger % change in air at the high end than the low end. This means a larger demand for jet sizing at the high end vs. the low end.
Point 2: Overjetting, and how size does matter
Most people tend to go overboard. It's better to be too rich than lean and burn a valve or piston. However, I keep seeing people recommending a huge size increase that isn't necessary. People end up with more power, but those who look deeper will find they're running rich so they're getting slightly suboptimal performance and definitely poor MPG. This also builds up a lot of soot and carbon from poor combustion! Running rich can also blue pipes or afterburn/overrun in the exhaust as much as going lean (this is the popping sound some people wrongly call "backfiring"). Ultimately, there are too many factors on any one bike even compared to other "identical" ones so you really need to do a plug chop or EGA to know what's going on.
Keihin jet sizes increase at a linear rate. Fuel FLOW does NOT increase at that linear rate. Why? Keihin numbers represent diameter in 100ths of a mm. Fuel flow (roughly, if you don't take into account the inconsequential difference in friction) is going to increase MORE than that because it's based on cross-sectional area. A 1" garden hose will flow MORE than twice as much as a 1/2" hose. By the way, Keihin sizes are rounded such that 72 is actually 72.5 (tenths of a mm?) and 78 is 77.5, which is why sizes always fall on 2, 5, 8, 10s.
Point 3: Calculating fuel flow with examples
Skip this and just use the charts if you like. I've spent a lot of time working with jet tuning/sizing on a few different types of bikes, mostly the Kawasaki Vulcan VN750. Generally by going to pod filters and different mufflers, people need 5-7.5% more fuel.
Let's compare a 78 to a 90:
In linear size and diameter, that's 15.38% larger. (Well, considering it's actually 77.5 vs 90, it's a bit different but let's go with 78)
78 = 0.78 mm diam, /2 for radius, then do pi * r^2 = 0.4778 square mm cross-sectional area of fuel flow. Keep in mind that it's a circle, not just squaring the measurement. It makes a bit of difference.
90 = 0.90 mm diam, = 0.6362 mm^2.
.6362 / .4778 = 33.15% more flow. So +15% size is actually +33% fuel!
So a 112 is 0.9852 mm^2, and going to a 120 is 1.1310, for a difference of 14.8%.
So when you're rejetting to a 90/120 you're going up TWICE as much on the primary as the secondary even if it's almost the same number of sizes increased (5 vs 4).
Point 4: Choosing jet sizes, bringing it all together
Jet sizes are going to depend on the change in AIR flow efficiency of the engine. It's one big air pump (not just a gullepump ;) ). How much of a jet increase do you need? Exactly proportional to the % of power increase you expect to get. Intakes generally are less than 5%, so it's no surprise that people who rejet at 10% or more just for pod filters notice they are running very RICH. Exhaust is what, maybe in the area of 5-10%? From my experience, both together are more in the neighborhood of 8-12% total.
That's just average across the power band though. Generally people are going to have independent pods and a more open exhaust, both favoring air flow at the TOP end of RPM. The increase is NOT the SAME % across the entire RPM range, so depending on what you do you could actually lose performance and MPG at low to mid range, or you might gain just a touch at the bottom but a lot more in the mid and high range. That is what you should (generally) be jetting for, keeping in mind that a hair rich is best at WOT to avoid overheating heats, pistons, valves.
So why recommend 90/120 on a CX500 when it's +33%/+15% at the low/high range? Why #40-42 pilots on a VN750 when that's +15-30%? That goes against everything we know. Even if the top end is good, a lot of people are too rich at 90/120 on the CX and 40/140 on the VN750. I'll make an educated guess that it's from the oversized pilots.
So what's a good jet size? I tested a lot on other bikes, and the best running ones were below the (high) usual recommendations. Guess what, they usually were best around 5% increased cross-sectional area (not jet number size). For a Vn750, that turned out to be only 1 size increase on the pilot jet dialed back but 2 sizes on the large, Or stock low jets with the idle screws turned out instead. That gave around 10% increase with a lot of people who only did the intake mod running a little rich, which gels perfectly with all of the above.
Minor point on shims/transition fueling
I have two things to add to my write-up here Firstly, the transition (sub)circuit, and secondly shimming.
The passages that feed the transition circuit further complicate jetting on SOME constant velocity (slide) carbs. Not all CV's have this, but the VN750 does. From my understanding, the pilot jets meter this fuel flow as well, however unlike the pilot circuit, its flow is NOT affected by the pilot screws. This means sizing up your pilots will increase your transition circuit even if you close the screws (for example to compensate for the huge 15% jump from #38 to #40s).
Secondly, shims often cause more problems than good. They can in some cases help to "smooth" the transition from pilot to main circuits on modified bikes, but they are not required and often are counter-indicated! They can and do affect the pilot circuit even just at idle! Shims were the sole cause of poor idle and hot start problems on 2 of my 3 personal VN750s and some others I worked on.
Here's a chart that shows how different factors affect carburetor tuning in general. This is not a VN750 specific chart and does not take into account the peculiarities of our transition and pilot circuits.
Where to start: VN750s
How much power do you REALLY get by bolting on intake/exhaust on any stock fuel injected motorcycle or car for that matter? Generally a little below estimates if you're lucky. I really cannot imagine someone cranking 1/3 more power out of a bike by bolting on an open exhaust and pod filters. It can't happen, so there just isn't that much of an air increase to necessitate the wasted fuel.
1. Start over from stock.
2. #38 pilots with opened screws, or for pods AND pipes AND low altitude consider the BIG 15% jump to #40s, but be prepared to dial your pilot screws way back to compensate for that excessively rich mixture and SKIP SHIMS at this point.
3. Now tune your high end to eliminate any stuttering at WOT under high load and speeds. I've found that most people are best with stock jets for just the ear shave, #138s for intake and exhaust and only occasionally #140. Most people don't need more fuel. Only very rarely and I mean once have I seen a VN750 that actually needed #142s to avoid a lean top end and that's because it did best with #38 and zero shims. I'm still not sure it didn't have another unknown problem because #142 is an excessive 16% more fuel.
4. Re-check your idle and throttle response. It should purr like a kitten even below 1000 RPM and tear up the highway at 100+mph at WOT without skipping a beat. If not, clean your carbs (take them APART and MANUALLY clean everything) and do a full tuneup. Then try again. I don't know of a VN750 with forced induction, so you do NOT need 40/142s or #42 pilots with any mains. If those run better, you have something WRONG with the bike to fix FIRST.
5. Shim only if you have a rough transition. I had one bike that would "surge" a bit only at a 55-65 mph constant speed due to slightly mistuned transition fueling. This is a case where you'd add 1 shim to each needle and test before going to 2. Shims will screw up your low end and idle if it isn't done right.
Thanks for posting, great info.
Thank you for this amazing write up. I'm actually looking at replacing my main jets today and this post explained a lot of what I didn't understand. Just to make sure I'm understanding this correctly, I'm looking to buy 40/138 with no shims. I have the following setup:
1. 2 K&N pod filters
2. Straight pipes with 8" baffles extended to the back of the rear wheel
3. Stock jets
You mentioned that only "occasionally" have you seen the need for 140, what is occasionally? Is it pretty much trial and error? I'm in the midwest, so low altitude, if that matters.
Overkill? Whats that?
I'll use my bike as an odd ball example.
So when i got it it was on 38/140's and by all indications was lean up top. (this is after i tossed the crappy pod filters and replaced with good K&N's)
Mods were, Ear shave, K&N pods, and Drag pipes (true short ****ers no baffles or anything)
I stepped up to 40/142.5's to see how it did, (this was after a complete carb teardown and clean) it picked up about .5 in the 1/4. Plugs looked right at WOT.
So if You have the most open exhaust possible and pods, you MIGHT need 142's at sea level. but for 90 percent of the guys you are absolutely right.
I wound up dropping back to 38/140's after putting a mac exhuast on the bike. (technically the new owner did as I made that suggestion as the exhaust had been on the bike for 2 days when i sold it.)
I feel though that with massive exhaust changes and intake changes what we really need is a better needle with shape.
just my .02
but kudos to you for going about this scientifically and not just stabbing in the dark. ...
Crowley
How about uni filters and a same-side exhaust with a collector at the end (two pipes to collector, one pipe outlet)? Running 42 140 with a shim. 38/138/0 is what I should start at, right?
the 42 might be a bit heavy on the pilot. but what do the plugs say crowley do a WOT throttle chop and that'll tell ya about the mains. and the pilot well hell with that exhaust i'm really not sure. as if you have some decent pulse pairing going on that really could use some extra fuel possibly. But then again it is just a 750. . . . how many turns out on your pilot screws?
Crowley
Plugs always seemed fine, on the dark side but not black. I get about 35mpg though.
Screws are 2 3/4 if i remember.
I have Jets coming in, I'm gonna do 38/138 2.5 and see how it is
I did the ear shave and installed 42/142 and 2 shims like suggested in the procedure. I also had straight pipe welded and added slip ons I believe with 8in. baffles and then wrapped the pipes. I'm getting popping only from front cylinder. Jets too large?
Crowley
Same problem with me, although for me it's just on decel from low % throttle, while in the lower half rpm... Lol...
Carbs tend to pop from being too lean, not too rich. So I would suspect some other reason, besides jets too large, for the popping.
With straight pipes, you need to read the plugs correctly to decide which way to go on the jets. Otherwise, you are just guessing. That can get expensive and time consuming while accomplishing nothing.
I think larger jets for the earshave alone are not needed at all. There have been a lot of posts in the earshave guide about this fact, but I think an edit should be made at the start of the thread to alert newcomers. It looks like many just read the first page and take off with it, then they have problems.
After reading this I decided to give it a try on mine. I originally had the 42, 142 jets with two shims on the jets and decided to move down to 40, 138 with no shims. I have the pilot screws out to roughly 2 1/4 turns. But reading this again I could turn that all the way in and still be fine correct? Even with the new jets coasting down hill in gear I'm not hearing any "backfire" which I believe the bike needs. Also before moving down to the smaller jets I checked the easier to remove plugs and I had a white tint to the tips. They were not wet. I want to recheck them in a few days to see if I notice any difference. Besides the ear shave I also have the Vance and Hines pipes. So just want to verify before turning them in that this won't cause a problem if the bike idle and rides fine that way. Or should I just move down another size on the pilots.
Can someone please give me a idea of what size mains and idle w/ shims i should be looking at. Doing Earshave, DeGoating, Coastering and live in the Mile high city so 5000 + above sea level. \
Thanks in advance.
I'd start with 40/140 and two shims.open up the covers for the air mixture screws and bottom out lightly and turn out 2.5 screws. each bike is different but should get ya in the ballpark.how about an introduction in the newbie section? thank you
I have that same issue of popping. more of grumble now on decel after many tests....rear cylinder only...I'm racking my so called brain to see if i can adjust the air mix screws just to have the same grumble pop on both pipes...but it is wicked cold here riding today and testing theorys...2 degrees i think with the wind chill...lol...but this post really helps ...great education..thanks...Im curious though ..would anyone know if it matters if the exhaust pipes vary in length - would that effect the detail of how the bike performs or would it matter for the back fire pop? bile mechanic I am not...i go by theory and possible reasonings.
You should get better mileage than that. I run about 42mpg but when I lean it out I get 45-50mpg and it runs faster, I run it at 42mpg because the plugs were just too light at 45-50mpg and I didn't want to worry about it.
Howdy all
New to this forum but not to motorcycles. I just bought an 06 VN 750 to ride around town instead of riding my Goldwing everywhere. This VN 750 is in excellent condition with only 2600 miles on it. I've owned many Kawasaki's over the years and really love Jap bikes.
The 750 that I bought was in the process of the ear shave and AIS removal when I got it. I finished the project by following the procedure listed on this forum which sounded pretty reasonable. I removed the carbs. Carbs were very clean so I didn't completely disassemble them. I installed the new jets and shims, After the new oversize jets and shims were installed and everything was re-assembled, the 750 started immediately and idles great. It seemed to stumble a bit when I first rev'ed it but not too bad. I took it for a ride and it has no power at all on the low end and I could only get it to 75 mph on the top end.
The mods on the 750 are;
ear shave
AIS removal
K and N pods
142 main
40 pilot
What do you think? I know this bike should run an easy 100 mph if n eeded.
Thanks,
Steve
2 1/2 out on pilot screws
what exhaust ya running?
1 - 20 of 54 Posts
