1 - 2 of 2 Posts
Discussion Starter · #1 ·
hi all, just finished getting new tires and lubing splines ( they are looking good- whew) and am in the process of putting the wheels back on. just can't seem to find torque specs for the front axle pinch bolt and front axle nut. are there torque specs for the rear shocks? any info will be greatly appreciated.
thanks and ride safe john
Hello Free, According to Clymer the front axle pinch bolt and nut is 9.5 ft. lbs.the front axle nut is 43 ft. lbs. Shock absorber mounting nuts, upper and lower is 26 ft. lbs. Rear axle nut 80 ft. lb. Brake torque rod bolt and nut 22 ft. lb. Hope this helps.
1 - 2 of 2 Posts
