I just my 750 back on the road and started hearing a tap seems from the front cylinder. It's a mild tap. Seems when I am on throttle but is less when l roll off. I think it's getting a little worse as time goes on any ideas?
If you don't mind, please review each section's description before posting. Thanks!I just my 750 back on the road and started hearing a tap seems from the front cylinder. It's a mild tap. Seems when I am on throttle but is less when l roll off. I think it's getting a little worse as time goes on any ideas?
No problem sorry iam new to posting on the forumThanks
No worries. If you need further assistance with anything related to the site, don't hesitate to message me directly. If I don't know the answer, I'll find it for you. (However, if you're needing assistance with your bike's troubleshooting, Spockster here is one of the most knowledgeable people around.)No problem sorry iam new to posting on the forum
He's helped me quite a bitHe is very knowledgeable I am trying to pick his brain about this tick. It dosnt seem like a rocker or a major problem but as we all know a little clip can be a major problem in time. Thank you for your help . I did however plug the large hose that runs to the valve underneath the seat. Iam waiting for a small hose from the rear cyl. Reed valve out let and hooking all of them back up to see if that may be my problem.
eBay probably has it or use heater hose. Or just block it all off. I have all those hoses I took off.Iam waiting for the rear cyl. hose and then doing all of the hook ups once . the rear hose was dry rotted so i am replacing it. Cant find the larger hose that hooks on the side of em. valve under the seat no one has it.
Its unavalable. So I the may extend it and fix it at same time.
Did you guys ever deal with Dave parts?He's helped me quite a bit
He ripped me off so beware of him /QUOTE]
How so? Was it through eBay? If so they usually help resolve problems.
Hi, sorry to interrupt. For discussions pertaining to transactions with others, please do so in the Off Topic section. Thanks!Did you guys ever deal with Dave parts?
