1 - 3 of 3 Posts
i want to put fuses on each wire from the stator but i am unsure the amps on each i was thanking 25amps each i tried to email tim but he has not answered in a week i thank he is super busy and my stator came
DO NOT FUSE THE STATOR.. we have found that by fusing the stator when one of the legs shorts to ground and pops the fuse it burns up the r/r almost as fast as the fuse blowing. not to mention a lot of other smaller problems. if you must fuse the stator, go with 30 amp fuses per leg.
DO NOT FUSE THE STATOR... we have found that by fusing the stator when one of the legs shorts to ground and pops the fuse it burns up the r/r almost as fast as the fuse blowing. not to mention a lot of other smaller problems. if you must fuse the stator, go with 30 amp fuses per leg.
x2 Slim ...I've read that here.
:smiley_th
1 - 3 of 3 Posts
