Is there a specific type of lubricant to be used on the throttle cables? I ran into rain a couple weeks ago and ever since then the throttle has been STIFF!! Sprayed WD 40 and a few other lubricants on the cables. I would see it drip from the bottom, where it connects to the carbs, so hopefully I had enough lubricant in there. The problem is it would be smooth for a day or two, but after that it would stiffen up again. Maybe I'm using the wrong lubricant?
D
D
