1 - 17 of 17 Posts
I'm a rider
This came on one of my VNs that I purchased a couple years ago and it leaked in literally 40 different spots. so I tried plugging it up with that epoxy that you squished together and it hardens hoping that I could use it as a spare tank just for feeding gas to engines that I had on the stand working on but even after $30 worth of that epoxy it never sealed up and it still leaks from over 20 spots.
The inside appears to have por 15 in it and it has it all peeled away it’s a complete dumpster fire
I just found the gas tank in the garage and remembered about it so I figured I would post some pictures of it.
I'm a rider
Yep i hung it on the wall.
I would just toss it. I do collect parts, probably way too many. But I don't keep anything if it is completely worthless. Is that tank from a U.S. Vulcan? I don't remember ever seeing a Vulcan tank with graphics like that before.
If restoring it is worth the effort to you, the existing liner can be removed with paint stripper. Use good quality stuff and give it time to work. With all the liner removed, fill the tank with water and tape over the holes. When the tank is completely dry (doesn't matter if some flash rust forms) use Caswell epoxy tank sealer. It actually adheres to light rust even better than smooth metal. You'll never have to worry about rust again because the metal is entirely covered with epoxy on the inside. https://www.caswellplating.com/epoxy-gas-tank-sealer.html
I have seen tanks so rusty the whole sides and top caved in. If it is that rusty it will have no structural strength,
I'm a rider
Discussion Starter #9
I'm a rider
Discussion Starter #10
1988 Vulcan. Here's someone else's video.
I'm a rider
Discussion Starter #11
Once it gets rusty enough, you can use it as a rustic punched-tin lamp.
I've stuck LED's in tons of things before and I have a strip with a remote control and programmable brain. It may end up lit before it's over.
I'm a rider
Discussion Starter #12
It's wall art. I don't need it. The POR15 they used before peeled back up when the metal split from the extensive rust damage.
I'm a rider
Discussion Starter #13
It's still amazingly solid, just swiss cheese. I'm a welder and I do sheetmetal sometimes. I've been planning on making a gas tank for one of my VN's and I'm going to use this one for a template for the bottom so I know it'll fit the frame.
I had a similar issue with my VN750. Kawasaki dealership told PO it needed to be sealed and used what I assumed was Kreem. It rusted underneath the coating, causing it to fail. I used several quarts of paint remover to get the sealant out, then used The Works toilet bowl cleaner, which is 18% HCL, to remove the rust. Tank is still nice and shiney 10 years later. I top the tank off after every ride to minimize corrosion, and ethanol gas absorbs what little condensate that may form.
Too bad it's in such sad shape. As you can weld, it would have made a great candidate for building a higher volume tank with it. Someone awhile back did this by splitting the tank along the sides and adding a strip of metal. Increased capacity to about 5 gallons...
Stone Poet. Kcdqg has it now. If I can find pics I'll dig em up
Sent from my A502DL using Tapatalk
  • Like
Reactions: One1
I'm a rider
Discussion Starter #17
A pictorial review of why POR15 doesn’t work and peels back out. I don’t know who did this to this tank, but if it were me I’d use muratic acid, naval jelly, THEN SEALER and cross my fingers. As bad as this tank is inside, I can’t imagine they used anything before putting the sealer on.
1 - 17 of 17 Posts
