I've done what I can to test the gauge, and I can't get it to register anything when connecting a ground to the lead. Seems to be shot. But also, the radiator fan is not kicking on either. I drained the coolant, refilled, bled, still no temp gauge, no fan. Tested the fan motor, it works.
I guess my question is, before I bust out the ohmmeter, can the water temp sensor malfunctioning cause the radiator fan switch to not work, or vice versa? I'm scratching my head as to how both of these things stopped working.
Could there be an air lock further down in the system, creating a void by the fan switch? If so, is there a more aggressive way to bleed the system than the bleeder screw? A lot of questions, I know, I'm just at a loss at the moment.
