1 - 3 of 3 Posts
Until the engine warms up good, and it goes away. I found both carb boot clamps loose on the air box side. I thought for sure I had found it, but no. I guess I should take the tank off to check the engine side.
Simple Solutions
i use a propane tourch without the the flame and spray propane around the boot and see if there is an increace in rpms no need to pull the tank to sest for a leak other use wd40 and listen for the rpms to drop... either way works ...
Thanks for the tip!
1 - 3 of 3 Posts
