Hello All
I have been going through the forums trying to go through and eliminate my starting issues and looking for a bit more help... Here's the low down so far..
Parked the bike after a ride with a just filled tank of gas - Garage Kept - Bike sat for aprox 3 weeks. I tried to go start it one day and wouldn't start seemed like a low battery so I got a trickle charger and let that sit for a few days. Came back and again kept cranking, backfired a few times - scared the crap out of me - but finally started and I took it out for a quick 5 min ride and parked it back in garage, hooked up the charger again.
A few days later same story cranked no luck backfired and drained the battery down so I quit. Decided to read what I could to see what was going on...
I took the battery out - It's an sealed battery MF says gel on it also - had it checked and charged by Autozone. I put it back in hours later, cranked backfired finally started went for a ride. I turned the bike off a coasted and tried to start it up, it wouldn't turn over. So I popped the clutch and it started back up. I repeated this a few times and it wouldn't start with the starter. I went back home and turned the bike off. Let it charger again. Few hours later, I checked the vent tube for the gas tank and left the gas cap open and tried to start. Thinking it was vacuum locked and wasn't getting gas. Again backfired barely starts let it run for a few cut it off. Tried to restart no luck just cranks a few backfires and I quit - Man them backfires are loud !!
Next day decided to check the voltage of the battery as I cranked it up 12 Volts when I put the MulitMeter on the battery. I cranked and it dropped down to 11 to 8 to 6 volts bouncing around. So I went and got a new MF battery just to check and it reacted the same way voltage drop and backfired. Went got my battery back and bought new NGK Iridium plugs put them in no luck still backfires. I took an old plug and connected them up to see if I have spark. The front cylinder fires on both plugs but looks weak light blue spark. The rear cylinder sparks intermittently and seems to backfire on that cylinder when it sparks.
This whole time I have always felt the starter was struggling to turn. Its not a solid cranking noise more of a rut-rut-rut-eeee-rut-rut. Not like a car or lawn mower like I use to repair a strong cranking wirrrr type noise....
I'm thinking of repair the starter at this point but was looking for more insite...
Thanks for any help.
Hope this isn't too long I tried to be as detailed as possible.
DT
DT
