1 - 4 of 4 Posts
85 VN 700
I've done some searching here and on the web - must be doing something wrong. I've seen reference to something "a little short".
I'd like to go away from the 3 line setup and to a 2 line setup (both full length to the master cyl).
Anyone have some part numbers for me that worked for them?
Thanks,
Curtis
Curtis -
I did some homework before buying my ss lines. I personally think it looks neater to have just one line coming into the mc from the fork split. Also, I like the reliability of a single connection to the mc. You lose the front brake and you're screwed.
I went with the 3 line setup and really like the feel (much firmer) and looks.
There is a photo of mine in the gallery.
Just my thoughts.
Jon
I got the Goodridge set and one of the lines was much too short. I don't know if anyone has had better luck with them. I ended up making my own set-up from Goodridge parts at bikebandit.com. I believe Galfer has a set-up that is known to work.
Good luck, Mark
Good luck, Mark
I got the Galfer 3 line set and it was fine.
Jon
1 - 4 of 4 Posts
