1 - 11 of 11 Posts
I have decided to take your advice and try to work on my bike myself this is my first bike and I don't consider myself very mechanical I was able to fix my kickstand switch and now my speedometer cable broke I bought a toolkit from ebay and a speedometer cable. when I replace this cable do I need to calibrate it or is it just as easy as hooking it up and going
Hook it up and go. Just make sure to always pay attention to how things are situated/routed before you take them apart.
Taking pictures before disassembling anything is a really good practice
Make sure the cable is lubricated before installing.
Might want to put a drop of locktite on the bottom connection. Had mine come off and it dropped the inner cable. Somewhere. :doh:
What's a good lube for the cable? I got a new one today but haven't installed it yet. Does the entire cable get lubed or just the ends?
Thanks.
... later I found a note I made a few days ago.... use "white lithium grease" for the speedo cable.
Discussion Starter #6
I did it my first mechanical fix (if you can call it that). Saved myself $100 by changing a cable by myself! Thanks for all the help.
Well done! Nothing more satisfying than being able to thumb your nose at the stealerships as you ride by. :beerchug:
I dunno how long your speedo was inactive, but if you hear a buzzing/humming sound while the bike is rolling, stop and take off the cable, then open up and clean the speedo before putting it back on.
Mine was inactive for a loooong time and when I put my cable in, I guess it was really dirty inside cause it hummed and I thought it would go away but it seems something inside the speedometer broke instead. Just a heads up in case it happens to you.
You want to lube the whole cable. Not a whole lot of grease, I put a dab in my hand, and run the cable through the grease to coat it while twisting it to coat the cable all over.
Discussion Starter #10
I'm set to go with the lube
If only it had 6th gear..
Good job! Yeah Lock tite is a good idea. Make sure the "ahem" thumb screw at the base of the speedo is pretty tight. Dragged mine around for God nows how long until I happened to notice I was doing 0 mph ... doh!
1 - 11 of 11 Posts
