1 - 4 of 4 Posts
How in the world does one remove the tach & speedo from their casings? My speedo is slowly rotating counter clockwise and I am trying to get it apart to see why also to replace the lights with LEDs. Any help would be greatly appreciated.
Mike
You have to pull the headlight out, disconnect the wires from the gauge cluster. Disconnect the speedometer cable and there's a bolt on either side of the gauge cluster that comes out. Then the whole assembly come off and you can figure the rest out from there. Couple of screw in back of the cluster come off and you should have access from there.
run a drill with a small square bit in the back of the speedometer where the cable goes to see if it's working properly, the problem could be with the cable or the gear it goes to on the front wheel.
Diesel Tech
Mine just wiggled off after removing the screw. The speedo and tach were very loose so I put a washer over the rubber mount to give it some compression.
1 - 4 of 4 Posts
