1 - 11 of 11 Posts
Discussion Starter · #1 ·
My speedo and tach covers and badly corroded and pitted. I believe they are chrome over junk metal and therefore can't polish them. I do not think the covers alone are available, only seen them as complete speedo and/or tach at > $ 200, not an option.
Anyone done anything creative to make them look better?
Considering sanding, priming, and painting them?
jdegreif said:
The covers are not available by themselves. I sanded and painted mine black. They came out ok but I should have spent a litttle more time on them so they would look better.
Ditto here. I painted mine black as well.
i have a 2000 vn750 and mine are just starting to pit & corrode. my plan of attack is go get a piece of 3mm carbon fiber to make a dash with & apply a thin 0.015 mm carbon sheet around the ring covers. hope to do this by july or august. hope it turns out. ride safe, john
This is a very common problem with our scoots. I painted mine black also and they came out pretty good. I was not smart enough to figure out how to get them off the bike easily so I painted them right on the bike with a can of spray paint
search the versus or other posts. Someone had found some covers for another bike that fit over the top of the upper cover.
Have a look here : BikeBandit.com always comes through for you :D (I did discover them to be significantly cheaper than many other OEM parts sources...
Discussion Starter · #9 ·
$ 196 for speedo & $250 for tach is WAY TOO rich for my blood.
I will sand and paint as others have done.
BTW: Ron Ayers is usually less expensive than Bikebandit.
Uhh... you said you only wanted covers. Look at parts 14025C and 14025D - respectively, Cover, Speedometer ( $25.84 ) and Cover, Tachometer ( $25.96 ). no bashing BikeBandit! :D Admittedly, it still leaves the problem of chrome rings around 'meters, but... new chrome cups are better than nothing, hm?
Discussion Starter · #11 ·
I'm not bashing Bikebandit, just that there are instances when Ron Ayers is less $$.
My chrome cups are fine (of course), its the "rings" that are corroded.
1 - 11 of 11 Posts
