Horsepower @ RPM 65 @ 7500 per Mama Kaw 52 per an individual test
Torque ft lbs @ RPM 47.7 @ 6500
1/4 mile seconds @ MPH 13.70 @ 97.6
0 to 60 in seconds we don't know at this time
Top Speed in MPH we don't know for sure (certainly over 100 mph according to several of us)
ENGINE 749cc, Liquid cooled, 4 stroke, V twin, 8 valves, DOHC, rubber mounted DISPLACEMENT 749cc
BORE X STROKE 84.9 x 66.2mm
COMPRESSION RATIO 10.3:1
FUEL CAPACITY 3.6 gal.
FINAL DRIVE Shaft
CARBURETION Keihin CVK34 x 2
IGNITION Electronic
TRANSMISSION 5 Speed
FRAME Double cradle, high tensile steel
RAKE/TRAIL: 32 degrees/5.0 in.
LENGTH 90.4"
WIDTH 33.5"
HEIGHT 48.2"
WHEELBASE 62.2"
GROUND CLEARANCE 5.9"
SEAT HEIGHT 28.9"
DRY WEIGHT 483 lbs.
BRAKES / WHEELS / TIRES SUSPENSION
Front: Hydraulic telescopic fork 5.9 in. travel
Rear: Air assisted dual shocks with, 4 way rebound damping 3.5 in. travel
BRAKES
Front: Dual Discs
Rear: Mechanical Drum
TIRES
Front: 100/90 19
Rear: 150/90 15
Vulcan 750 Top Speed
Always good to know we have the fastest of the Kaw Cruisers (well except for the Meanstreak)... This info is dated, missing the 1600, but still is interesting. I ranked on 1/4 times. Quarter mile elapsed time/ending speed
1500 Mean Streak 13.76/95.6
VN750 13.98/93.1
800A 14.00/93.6
800 Classic 14.34/89.9
1500 Drifter 14.56/88.9
1500 Nomad FI 15.49/88.1
800 Drifter 14.56/88.9
1500 Classic FI 14.98/88.7
1500 Classic (carb) 15.03/85.3
FINAL DRIVE Shaft
IGNITION Electronic
LENGTH 90.4"
WIDTH 33.5"
HEIGHT 48.2"
WHEELBASE 62.2"
SEAT HEIGHT 28.9"
DRY WEIGHT 483 lbs.
BRAKES
Front: Dual Discs
TIRES
Front: 100/90 19
Rear: 150/90 15
VN750 13.98/93.1
800A 14.00/93.6
