1 - 5 of 5 Posts
Any one please help out there!
I have just charged my battery up after the bike stood for 3 weeks without use. When i tried to connect the negative lead it threw up sparks at me. I have not been able to start the bike, what has gone wrong? Before i took the battery off the bike was trying to start even though the ignition was off and the electrics were shut off!:confused:
Tiger.
Your solenoid could be bad. The start switch may be stuck on. The junction box relay may be stuck on. I would check the solenoid and start switch before messing with the junction box.
Member? ... check.
Sounds kinda like a welded/stuck starter relay. The big one up under the right side of the seat.
Discussion Starter #4
Many thanks guys, will check switches and relays as suggested. Would damp or even dirty connections cause problems to either components?
A million thanks guys!!! Just took the relay off cleaned all connections and bingo she's now running sweeter than ever, can't thank you enough.
Happy days!!!!!:smiley_th
1 - 5 of 5 Posts
