Try this for plug wire replacement - From the VN750 yahoo group
Stock answer from me...
For the VN700/750
You should consider buying NGK plug ends if you haven't already. They are
great looking and my directions are based on using them.
Dennis Kirk:
[email protected] or 1-800-328-9280
2 Part# 20306 - XD05F Spark Plug Cap $3.30 a piece.
2 Part# 20789 - NGK Spark Plug Cap/LD05FP $4.80 a piece.
Grab yourself a roll of 8 mm non-resistor type wire from your local auto
parts store or speed shop. They may have to special order it. Even a 50
foot roll costs less than the Kawasaki replacement option. I chose bright
yellow... Looks good on my black and red bike IMHO.
Here are the wire lengths you will need:
2 x 11.5" long
1 x 14.5" long
1 x 20.0" long
Measure your old wires to make sure it'll work. If you can get 60", you
should have some to spare.
I cut my wire with a sharp scissors and stripped off the yellow insulation
so that the wire slipped into the coil easily. If you can get it to slip
into the coil with the yellow intact, that's even better. Take the rubber
"O" looking thing along with it's plastic cap (if intact) and use them on
this new wire. I had to squeeze the wire into these "O" shaped holders on
the coil end with a very small screwdriver. I pushed the "O" onto the
wire
as far as I could (about 1/10 of an inch) and then "stuffed" the yellow
insulation under the "O" thing. This "O" thing holds the wire in place
along with the cap that screws onto the coil. Obviously, put the wire
all
the way into the coil with about 1/8th inch of room between the "O" thing
and the edge of the coil. Then use the screw cap to tighten the wire down
and into the coil.
The plug ends "screw" onto the wire if you buy the NGK I told you about.
Just make sure you have the proper parts at hand and already slid up the
wire before you do this or you will have to unscrew the ends and start
over.
The "short" ends have a tighter rubber seal that is a pain in the tuckus.
Be prepared to work that baby on by hand for a bit. Some people use
dielectric grease to make it slide better...
Joe in Northern, NJ
V#8013 ‘86 VN750 (For Sale!!!)
Ride a motorcycle in or near NJ?
http://tinyurl.com/4zkw8
http://www.youthelate.com
Young Life? eMail me!
Born once - Die twice. Born twice - Die only once. Your choice...
Cedar Grove, NJ Bike Night! (973) 239-1400
