Hey Sockster, I'll send you a message about your air box. "in one piece" is definitely a better status than mine! Fingers crossed those dang screws don't leak.🤞I guess I'll be asking around for carbs if they do.
Hey Sockster, I'll send you a message about your air box. "in one piece" is definitely a better status than mine! Fingers crossed those dang screws don't leak.🤞I guess I'll be asking around for carbs if they do.I've got an airbox in one piece.
The chips broken at the end of the holes shouldn't hurt anything, as long as the screw doesn't leak.
How far are you from Lancaster county PA? There's a basket case I posted earlier.Hey Sockster, I'll send you a message about your air box. "in one piece" is definitely a better status than mine! Fingers crossed those dang screws don't leak.🤞I guess I'll be asking around for carbs if they do.
There was a cap?! You learn something new everyday. I am about 3.5 hours from Lancaster.How far are you from Lancaster county PA? There's a basket case I posted earlier.
I don't think the screws will leak, like you said they're recessed. They had space for a cap they pressed in there.
Yes, they capped the air screws to stop people from adjusting the carbs.There was a cap?! You learn something new everyday. I am about 3.5 hours from Lancaster.
A hose attached to a plastic bottle, fill the carbs up. They sell fuel bottles that will hang upside down like a medical IV bag.UPDATE:
I finally was able to get back to the shop. I got the 'new to me' air box installed and everything else put back together. I must have smashed a wire pretty good because it sounded like it was grounding out when I tried to start it. So, I took the gas tank back off and looked at everything. Nothing obvious, so I redressed all the cables making sure the loom tubing was protecting everything from ground. then I tried it again. The engine was trying to turn over so I put the gas tank back on and after turning it over a few times, it started no problem! It sounded good, it idled well, it revved great. I thought I was done and that I would be ridding in no time. But am not the mechanic I thought I was. The front carb is leaking pretty good. So I have to take everything back out. 😢 I did see a video by Andrew Roth, maybe? where he pulled the air box half way out and then lifted the back up with a ratchet strap to his ceiling joists. He was able to get the carbs out that way.
My new question for everyone, How do I test the carbs to see if they are leaking before I put them back in? Do just try and poor gas in to the inlets until it fills up? Do need to add vacuum to it some how?
