2) Evaporated gas with ethanol
Was probably the carb for the rear cylinder, if the bike is stored on the side stand, that carb is tilting to the high side and always dries out fast.
Not sure about removing the broken mixture screws. A really small reverse twist drill bit? Don't want to drill too deep and get into where it's tapered. That's going to be a tough one.
I never synch CV carbs, as long as the throttle plates open equally, they should be good.
