1 - 5 of 5 Posts
Discussion Starter · #1 ·
I'm always down to tinker unnecessarily on a bike. The single carb conversion threads caught my eye.
Found this on ebay. Price is steep ($300!), but it looks like bolt-on parts for a simple conversion. Includes nice metal 2-to-1 manifold, carb, jets, etc.
CV40 carb clone, still has room for twin throttle cables (would need cables with elbow right angles I think).
Seller says too you can point out the left or right side (not sure if that'd make a difference). Curious what kind of clearance you'd have with tank in stock position. I guess the only other thing you'd need would be an appropriate filter.
Should I keep dreaming or get back to work on parts that really need fixing?
Nickel Auto part Bicycle part Gas Machine
I can see where it's tempting, but knockoff carbs can be a headache, not always but when they are, look out. Then you may still have to work on jetting unless they have worked that out.
You can do the earshave under $100 depending on the brand of filters, Uni versus K&N.
Maybe if I could buy the manifold separate and supply my own carb. But after the earshave carb work isn't so bad.
Now if the stock carbs are broken, physically parts broken off, then it becomes a better option since prices are high for used carbs.
Discussion Starter · #3 ·
Thats a good point about the jetting. Between an oddball carb and my oddball V&N exhausts it'd be jumping into the deep end trying to get that balanced.
It indeed looks like the seller also sells just the manifold separate. I might pick that up just in case down the road I get the spirit again to swap out some carbs.
Reflecting on the bike's vintage I almost feel like I should start stockpiling parts. Feel like as time goes on non-OEM upgrades are going to be increasingly rare.
With your exhaust, I would definitely want to know what jets are in the carb. But it's uncharted territory so you'll probably have to find the right jets.
At the moment I don't see why one of the stock carbs can't be used. Just put big jets in it, and shim the slide needle.
To stockpile parts, I would make an ebay search, sort by newest listing, save the link, and check it every day. Finding a cheap parts bike is valuable if you have room to keep one.
I was contemplating giving the single carb a try. I too like to tinker (If you saw my shop!).
There was a old timer mech in town that had a great rep for knowledge and he loved to chat (He built and wrenched for flat track racers in the day). He shared with me, the issue with a V-twin and single carb conversion is AIR not fuel. He, like the kit above, suggested a 40mm single carb. I think my bro's 95 883 had a 40mm. The 1200 sportster uses a 42mm.
He also suggested trying a flat slide. I have a complete VN700 under 10k miles on my to-do list. Might give it a try some day.
1 - 5 of 5 Posts
