ㅤ
What's the big benefit of the Tuxedo pod? That you don't have to remove or tilt the engine to replace the stator?
That's it.
Has to be done just right for stator alignment and to prevent oil leaks.
Im trying to test my charging system.
To test I unplugged the R/R my pulling this connector off of it:
Then I attempted to locate the bullet plugs. I think these are the right wires, behind the Vulcan vanity plate, coming up from the underside of the bike and connecting to the the wiring harness, but they aremt bullet plugs at all. what do you call these? Maybe they are bullets but theyre too dirty.
So i tried testing those three wires by unplugging the R/R, setting the meter to ohms at 2k (200 was my only other option down from that), and touching the other lead to the engine along one of the cylinders:
I didn’t really understand the readings. When I saw “1” I turned the meter down, as in when it was reading 1 on 2K, I turned it to 200. Then I was getting readings like 20 or 30 on a couple of them. What should I be seeing?
If we trust the meter, unfortunately it's showing the stator is shorted to ground. Seems unusual to have all three legs shorted to ground.View attachment 56045
Here’s my meter. Set to ohms 200 here’s what I get (with the RR unplugged):
Each wire to engine block: they all start high and start settling around 1.8 but then slowly tick down to 1.5 or so as I sit there.
Battery negative to the same spot on the engine: starts around 1.2 and slowly ticks down to 0.9
That's the diode test, diode symbol.Instead of an ohm reading does the meter have a continuity test? Not sure if that’s the symbol right above the “ON” switch. Usually it’ll read continuity and beep if it detects ground. You don’t want to read continuity between the stator and ground.
Not sure I trust the meter.Can you elaborate on why you're saying that and thereby educate me?
It looks to me like the meter is showing continuity to ground on all three stator fields, or "legs". Each wire is a leg.When I set the meter to 200 ohms, the same as I've been doing on the bike, it reads the same as the bike, and as the battery: 1.5 or so which ticks down to 1.2 or so.
Sorry Sir, I’m going to have to respectfully disagree, that’s the continuity symbol. A reading of “1.” Means “infinite resistance” or “open” so that’s what to want to see from the leads to ground. Here is my meter on that setting. I didn’t have it in front of me to look earlier.That's the diode test, diode symbol.
What does your meter show when you touch both leads together on the same setting?
Yours does have the audio symbol beside the diode symbol.Sorry Sir, I’m going to have to respectfully disagree, that’s the continuity symbol. A reading of “1.” Means “infinite resistance” or “open” so that’s what to want to see from the leads to ground. Here is my meter on that setting. I didn’t have it in front of me to look earlier.
I think we just need to talk him through the meter for sanity. When my stator was dead I did the resistance test between leads of the stator but continuity from the lead to the chassis (ground). Maybe I misread the posts but thought he was testing resistance using the 200ohm setting and touching a lead to ground instead of lead to lead.Yours does have the audio symbol beside the diode symbol.
He got 1.xx on all three tests... Lead to lead, battery negative to engine block, and each stator lead to ground.
If 1.xx is open, then the entire test is invalid because there was no ground for testing. Meaning the engine isn't grounded.
Or I'm confused.
For the ground test, he should be touching one lead to ground and one lead to each stator wire. A good stator will show no connection to ground.I think we just need to talk him through the meter for sanity. When my stator was dead I did the resistance test between leads of the stator but continuity from the lead to the chassis (ground). Maybe I misread the posts but thought he was testing resistance using the 200ohm setting and touching a lead to ground instead of lead to lead.
Either the meter is bad, or all three of those grounds are solid. Except the stator fields shouldn't be grounded.If the same resistance shows on the multimeter when I touch the leads as when I test any other circuit, the multimeter must be bad, or I can assume there's the same amount of resistance in all the scenarios?
I hate to crowd this thread with trial and error. It's such a helpful thread. I will get a better multimeter that at least passes a resistance test and I will test again.
