I am rapidly becoming VN750.com’s problem child, so I apologize in advance. I have looked around the site and while there seems to be quite a bit of discussion about oil changes and plug, strainers etc I am am not seeing anything about this...
With nothing else in the hole, no strainer, grommet, washer or spring, the plug spins in freely until it doesn’t with about 1/8th inch to go. I have inspected both male and female threads for burs or cross threading. I have cleaned the threads with a toothbrush, wire brush and a bottle brush. The plug came out without any problem or indication that going back in might be a problem. When it stops up, I can continue with much more torque than what’s called for (14lbs?) but I’m terrified of stripping threads in the crank case. I have tried many times and the plug stops in the same place each time.
Am I missing something?
