1 - 8 of 8 Posts
2005 Silver
Had new MT66s put on yesterday and they tried to tell me that the ACCT needed replacing for $360 (don't think so) So when the bike is cold I can hear very faint valve train noise don't think there is a quite chain driven timing set. I can hear the "whine/wherr" noise if I take around the block w/o a helmet on. With helmet on I only hear exhaust. From the sound of this problem I would hear something off with or withoput the helmet. I bought the bike last year and it had been sitting for almost a year. I have noticed no new nosies in that time. I would expect it would have gotten louder if the chain had slack in it that long. I tried the GAMBO trick lastnight they both turned 5-6 times easley CW and then very quickly back CCW when I let the screwdriver slide in my hand. If they were bad I don't think they would be so "snappy" going back. Just wanted to get everyone's experance who has for sure had this problem. Thanks in advance.
PS I think I will order the kit from TOC since $35 to be sure seems like pretty cheap insurance. Now that I have got a good look at them seems like about an hour project to rebuild them. (The shop told me 1-2 hrs to replace them with new units. Please I could swap them out in 45mins and I'm not the pro. Guess the tires don't generate enough profit when they only get about $70 labor to mount and balance them, Was a local small bike shop and not dealer also I try to support the little guy but damn)
When the ACCT goes bad...you will hear it. Before it even gets "bad" you will hear "tapatatapata" sounds, which go away after the bike warms up. If they don't go away ....then you need to take a look.
$350? .......You can send me $175 for the diagnosis above. ;)
Before you spend $35 on the HD TOC springs take a look at wibs ACCT to MCCT conversion.
It was done for $7 for the front cylinder with parts from the local hardware store.
http://www.vn750.com/forum/showthread.php?t=17917
No shipping, no waiting, and probably quicker than putting the TOC springs in.
Also totally reversible if desired.
For 50$ I will advise you to go directly to TOC mcct's. Don't bother with the stronger springs. In some cases they will not work.
I went with the TOC springs and it worked out fine for me.
Patriot Guard Rider
2005 Silver
Discussion Starter #7
So did some more digging and testing. With the bike cold and the caps off the ACCTs I started it up and slowly turned them CW and then I heard what they sound like when its not right. let them snap back and just normal valve train noise. No way they are bad yet. They were just trying to sucker me and that pisses me off the most. Hell they even messed with my clutch lever adjustment so the lever snaps back tight but my fingers are not long enough to gracfly enage from a stop that way. I just wanted rubber and the final drive givin a once over and a lube. Guess I need to stick to me myself and I for the work.
1 - 8 of 8 Posts
