1 - 6 of 6 Posts
I started to flip through the electrical section but I kept getting sidetracked so I figured it best just to make a new post.
A buddy of mine was running behind me on the way to work this last week and noticed that my right side running light wasn't lit. I hadn't noticed it before but I had checked to make sure my blinkers worked before I even bought the bike. So I just assumed I blew a bulb, but when I went out after work I checked it and the weird thing was the light was out but the blinker on that side still worked. I assumed maybe it had a double bulb back there or something. Anyways I went out today to check the bulb and wouldn't you know it there is only one bulb. I pulled the one off the side that was working and switched them to see if maybe something was wrong with the bulb itself but the bulb from the working side wouldn't even light up, and the bulb I pulled from the side that wasn't working lit up just fine in the left side.
I was wondering if anyone has run into this and could point me in the right direction as to how to solve it. I flipped through my Clymers but it wasn't much help and you guys are usually better at spelling things out for me. Anyways thanks to anyone that can help.
The rear amber blinkers do not function as running lights, only blinkers. They use a single filament 1156 bulb that is only on (blinking) when the turn signal is activated. However, the front amber blinkers do act as both a running light and turn signal and use a dual filament 1157 bulb (same as the brake/running light bulb).
So, it sounds like you have a short somewhere in the rear blinker.
After I read what you wrote I went and pulled the seat and followed the wires from the left blinker (the one that is working like a running light) and all of the connections/wiring are solid no splits or battery acid on them up til it leads to the larger group of wires by the battery. Its weird that the bulb lights up just like the fronts as far as with the blinker off only the tip lights and when you turn on the blinker it lights the whole bulb. Maybe I can get away with getting the proper single filament bulb that you mentioned and see if it doesn't just quit lighting. Knowing my luck though the whole bulb will just light up and you wont be able to tell when I have my turn signal on. Either way I will give that a shot tomorrow. Thank you sir for the help.
Love My Baby
You swapped bulbs and the right one worked properly (I think) when placed in the left side, so it's not that bulb. It's possible you have two different types of bulbs in the rear turns. The bulb that only blinks when the turns are on is the correct bulb. Make sure both are the same and if not, buy another one just like the one that works properly.
However, for the bulb that only blinks when the turns are on (the one originally on the right side), if that bulb lights up as a running light when placed on the left side, you have a wiring problem somewhere.
Yes, if you have an 1157 bulb in the left side that is lighting up as a running light, and working as a turn signal too, replacing it with the proper #1156 bulb should solve the problem.
However it still leaves me confused as to why a single contact socket will make an electrical connection with even one, never mind both contacts, on a dual contact bulb base.
Let us know if both sides only light up to blink when the new bulb is installed.:smiley_th
Discussion Starter #6
A buddy of mine fixed this for me today. Come to find out someone must have rewired the lights at some point. They had the front turn signal/running light wired in backwards so it was keeping the light on in the back. All he did was switch the wire going to the turn signal with the one going to the running light in the front and the back light was fixed in the process. So i guess if you ever wanted running lights in the back all you would have to do is wire the front lights up so the running lights are tied into the blinker and vice versa. Always good to know someone that knows more than you about bikes I Guess lol.
1 - 6 of 6 Posts
