1 - 4 of 4 Posts
I have to remove my engine to replace my stator. Im to the point where i need to disconnect the drive shaft. The manual says remove the front bevel gear case. is there a way i can just disconnect the shaft and remove the engine with the transmission installed?
Not that I know of. Also found it much easier to put the bevel case on by removing the rear wheel and unloading the spring tension.
Jon
You know it's no longer necessary to remove the engine to replace the stator, correct?
1 - 4 of 4 Posts
