1 - 2 of 2 Posts
Replaced VR. Upon attaching all cables, when I attached the VR plug the Neutral and oil indicator lights turned on. Ignition switch was OFF. Tried another VR, same thing happened. Suspect the fuse junction box. Is there any way to verify this. Replacement junction box is 165.00 with no return. Or am I missing something else. I have replaced VR in the past without any problems.
Did you by chance splice the brown and white wires on the bike's harness together? Brown should be left disconnected or on a dedicated pin if the R/R has a monitor pin.
1 - 2 of 2 Posts
