1 - 14 of 14 Posts
Discussion Starter · #1 ·
Good afternoon, I recent purchased a 98 that was in the middle of a bobber project. I am 90% done however there were no turn signals on the bike. I purchased turn signals how I have not been able to locate what wires need to be hooked up. All the wires are cut and taped up. Can you lead me to what exact wires are for the rear tail lights. Thank you I really appreciate it,
Mark
Both sides need black/yellow for a ground. Positive signal is carried by grey on the right, red on the left. Hope that helps.
Discussion Starter · #3 ·
Awesome, Thank you Caleb. Backs are now wired but not blinking, I do need to wire the fronts, do you think that is why the backs are not blinking?
I would have expected them to blink at double speed with the fronts out. Not sure - somebody better at electrical can answer that. If you have a meter, you can verify continuity between the switch, flasher relay, and blinkers.
Behind the battery box under the seat.
This conversation was really helpful! I’m going from aftermarket to OEM turn signals so the color identification will help a lot.
Another question, should the signals burn all the time when the ignition is on? Currently they only flash for L/R/hazard. Taillight and headlight work this way currently, but all the images and videos I see of the VN750 markers are also on.
Thanks,
Brian
Thanks,
Brian
Only the front turn signals have running lights, the rear signals don't have them.
My bike has three wire aftermarket lights on the rear, so it does have rear running lights in the turn signals. You just connect the third wire to the tailight circuit.
Ok, that makes sense. There were two power wires in the headlight bucket, one of them resulted in a solid light. Do you also happen to remember the color of the front turn signal wiring? I tried to look it up but everyone wanted subscription or money to access…
Dr
Don't recall, but there's a color wiring diagram pinned in the electrical section. Blue and gray for left/right hot? All grounds are black with yellow stripe. Double check with the diagram.
Those wires in the headlight bucket are accessory wires for add-ons, hot all the time. There's another pair behind the right side cover.
Here’s a screen shot of the front end wiring colors if you can’t find the full file
Two wire fixtures will eliminate the daytime running lights if you want to go with them. Stock uses 3 wire in the front and 2 wire in the rear. Like Spockster mentioned you can wire in the 3rd in the rear if needed. But regardless the green and the gray are the turn signal circuits with the black yellow as the ground. The blue wire is for the DRL
1 - 14 of 14 Posts
