1 - 8 of 8 Posts
My right rear turn signal always worked up until recently. It is all Stock.
So I thought replacing the bulb but still does the same thing. I'm guessing my flasher relay might be a problem.
But any ideas would help.
If you think it is my flasher where would it be located at and what part number.
Thanks
Tom
It works sometimes and others it doesnt?I'd look for a loose wire or ground.check the connectors for corrosion.
The connections are under your seat. Reference a wiring diagram for the proper wires but inspect generally for corrosion. Also, you could have corrosion in the bulb housing.
1 - 8 of 8 Posts
