Yes the brown and blue where do they lead to since I’ve disconnected them I no longer have turn signals eitherIs this the connection you’re talking about ?
Weird they were working perfectly then then the two wires got disconnected for a stator job now they do not work I’ll have to take a peek when I get home from workThe brown is v+ from the battery via the ignition switch, and is shared with horns and some dash lights (which shouldn't be affected by disconnecting that plug). The blue goes straight to the brake light.
The turn signals are basically unrelated.
yes can you send me a picture of where that leads too?Is this the connection you’re talking about ?
I don't have a picture, but they cross over to the left side of the bike, between the frame and the lower front of the engine (near the starter). The connection point is basically the bottom left corner of the radiator.yes can you send me a picture of where that leads too?
I was pretty good with everything tearing it down of course the one thing I didn’t take a picture of is the one thing I can find and now my bike will not start was running yesterday the. Just died and will not start I’m over this bike 😅Thanks for confirming, I wasn’t 100% sure. I said that earlier assuming I’d be corrected if wrong.
But, the lesson learned here should be since we’re in the age of the smart phone, take pics as you break things down![]()
Spring is attached but it is rusty so could that be the fault?For the pedal not returning up, the spring on pedal needs to attached. It can be seen in the pic by mmart
No.Spring is attached but it is rusty so could that be the fault?
"Endeavor to Persevere!" - Chief Dan George- "Outlaw Josey Wales"I was pretty good with everything tearing it down of course the one thing I didn’t take a picture of is the one thing I can find and now my bike will not start was running yesterday the. Just died and will not start I’m over this bike 😅
